Post by subevo on Nov 1, 2009 13:28:09 GMT
Post by fuoriserie on Nov 3, 2009 21:06:39 GMT
good work.....  , looking forward to more pictures of your build.
Post by ha54sym on Nov 12, 2009 13:23:52 GMT
Hi there, kit looking god so far.
Can I ask if you bought the full kit or the Economy 7 type starter kit?
Dave
Post by mightylad on Nov 13, 2009 8:02:16 GMT
looking good chaps! keep up the good work...
Post by subevo on Nov 13, 2009 11:34:56 GMT
the only option available was the full kit from mev.£6300 delivered on 1st sept 09 wheels were bought ourselves £500 engine driveshafts etc from the ford centre on ebay.£1200 for st170 focus conversion kit.
just installing engine now .but need to modify engine chassis mounts.silly me thought it would drop in no problem.no chance.
Post by subevo on Nov 13, 2009 20:16:54 GMT
Post by nigel on Nov 14, 2009 8:02:55 GMT
Post by subevo on Nov 14, 2009 20:54:24 GMT
hi i cant seem to get it to work.every time i try then go to preview it dosent show picture.
Post by nigel on Nov 14, 2009 21:04:37 GMT
hi i cant seem to get it to work.every time i try then go to preview it dosent show picture. Check you photobucket settings, ensure that you can 'Share the Album' this might be your problem
Post by subevo on Nov 18, 2009 20:30:46 GMT
is this sump angle ok.rest of engine block sits level.
Post by subevo on Dec 26, 2009 12:17:03 GMT
forgot to mention the reason i couldnt post pictures is that the information in the post pictures section appears to be wrong.
it says right click "direct link" but it should be" img code" anyway i can now get it to work.hope this helps someone.
outlander
Full Member
" Drive it like you built it ! "
Post by outlander on Dec 26, 2009 16:41:35 GMT
The sump should sit level, yours seems to be at an angle.
Ade
Full Member
Mad Max upgrade in progress
Post by Ade on Dec 31, 2009 9:24:22 GMT
subevo,
Did you ever sort out the sump angle issue?
Im goin to be sitting my ST engine in soon and wanted to know if youve overcome this ?
Cheers Ade
Post by subevo on Dec 31, 2009 20:01:18 GMT
i think its caused by the fact i moved my engine back maybe too far so now the lower tie bar holds it in this position.if i moved it forward a bit more the sump would sit level.looking from above however the engine sits staight and level you wouldnt suspect anything is wrong unless you look at the sump angle.to be honest i cant be bothered moving it.everyone who has had a look thinks its ok.the picture angle is making it worse.if i made a shorter/longer tie bar say 10mm the sump would sit level and the engine would lean forwards.my main concern now is getting the wiring sorted.i will look at a focus st170 just to see what it looks like.its easy to fix if i could be bothered.
outlander
Full Member
Post by outlander on Dec 31, 2009 23:20:17 GMT
It may be an idea to level the sump, not sure where the oil pickup is, but if its on the high side there could be problems with oil pick and that would cause you big problems.
Just a thought
