Post by welshmarks7 on Mar 19, 2012 23:37:32 GMT
Hi guys, can't find anything that gives a definite answer for the specific trackrod end for the RD alloy uprights. I have got sierra and focus types but they won't fit into the insert! Please any thoughts or advice. Regards Mark.
daydreamer
Junior Member
Sonic 7 - 1.8 (standard)
Post by daydreamer on Mar 20, 2012 0:28:50 GMT
Hi Mark, I also have the rally alloy design uprights and I have used RS2000 track rod ends, available from RD. In the picture below the track rod end is partially covered with a plastic cover. www.rallydesign.co.uk/product_info.php?products_id=7332 There should be a stainless insert that goes in the steering arm on the alloy upright that adapts the hole to accept the track rod end. This adds the taper to what is a non-tapered hole that receives the track rod end. This is part of the alloy upright kit. In the picture above, this looks like a large silver washer between the track rod end and the steering bar on the alloy upright. Remember, when changing the track rod ends in future that the stainless insert needs pulling off the old track rod end and moving to the new one. Regards Daydreamer
Post by welshmarks7 on Mar 20, 2012 10:03:47 GMT
Hi Daydreamer, much appreciated, I was concerned that the trackrod ends that I tried weren't going all the way through the tapered insert, hence the post. Good news, I will now source some RS2000 ends.! cheers for now Mark.
Post by airforceone on Mar 20, 2012 10:26:59 GMT
RTR supply the exact ones you need for the alloy uprights just give them a call, think they are around 25 pound delivered.
Ned.
